Hello, buttons are duplicating next to each other when dragged off a custom menu to delete them from that menu.
They’re also switching to another menu item randomly when trying to delete the same button again.
For example when I tried to remove the Trim brush by dragging it off the menu (holding Cntrl + Alt with custom UI enabled) it duplicate itself and switched to a Move Topo brush. Very odd. I read that this could be caused by a roll over custom UI between versions but I got the same result customizing the default UI as a test. Maybe need to do revert the custom assets I’ve added to folders? Start default? Anyway thanks if anyone has any suggestions.
