well every time i open zbrush i have no active points counter and half of the transparent button on the right is cut off and everything under it
What’s your display resolution?
ZBrush requires 1284x1028 or higher. If yours is less, the UI elements won’t fit. You could try reducing their size in the Preference palette, but there’s only so far you can take that.
yeah, i had to adjust the size in prefernce and it fits now, thanks
