Need advice if possible.
At the moment have two computers working together by way
of a belkin splitter.
One Mouse, one keyboard, one monitor, divided among two
computer. ( You hit the scroll lock button to select computer.)
Is there anyway to integrate a second ( and much larger) monitor
into the existing setup so that it will play with the two kids.
Also.
First time trying a two monitor setup, can someone advise how to
set up so that for instance the tool bar is on one monitor and the image
is on the other.
Thanks for any help.
I dont have experience with 2 monitors hooked up with 2 computers
but i guess it should be possible as it is with one.
Windows automaticly leaves the first screen as main one with
the start bar at the bottom.
2nd is empty and you just push the program window you want onto
it.
Have a look at your graphic cards control panel.
Theres plenty of setup options with both ati and nvidia.
Thank you Mr Stu.
More crap I accumulate, worse it gets.
