Hi
Here are some ZProp Blades…
All the above blades have been created from the Cube3D primitive, but you may want to try other primitives (such as Sphere3D).
Hope this helps
Hi
Hope this helps
Yesterday I brought back an old tutorial from Pixelator.(ZBrush Props! part 1) Here is another one in the same series…
Hope you’ll enjoy and like aurick post your findings.
jaime
Hi all!
I have a doubt. How I come back to the edition mode of a model after leaving it? Exists this possibility?
Hi Xexas. This is one of the most common questions people ask. Here’s a link to a thread where this was discussed: Exiting Edit Mode.
You’ll find lots of helpful information like this in the QuickLinks section at the top of each page. Pay particular attention to the section on ‘New Users’.
Have fun,
dave
Tanx Dave
this tip was very opportune!
Im not sure if this is jsut me, But When I try to do Deformation it crashes And also
When it says Apply Skew 100 does that mean apply skew 100 to XYZ or what please help im still trying to learn
And also when it says Squizx
IS taht Squeeze X?
hey man im new 2 zbrush and have been tryin 2 figure out hw to do blades, this is wicked man!
thanks!!!
do u know any other weapo if so, can u post sum tutorials?
thanks again!!!
jonny
Hi Pixolator,
I have the same problem as Heney in ZB3.1. In step 3 of the first blade zbrush will crash after rotating 90 degrees. It’s also impossible to create a Hdivide and Vdivide in step two of both 128. If I type 128 in Vdivide and press enter it automaticaly changes to 129. Then I go to step 3 rotate 90 degree in Y and a new ( meshedup ) cube appears. On the same moment zbrush crashes.
Marcel
If I wanted to make this a polymesh to be uploaded into a game, how would I go about it? After I initialize the presets and drag the shape onto the screen, normally what I would do is type T then make it a polymesh…but zbrush always crashes if I go that route…If I do the tutorial just like it says…it turns out fine but I can’t make it a .obj file that works in world…I’m using Second Life as a medium
Any help on this would be greatly appreciated…
Thanks!
