Hi
There are several methods that can be used in order to achieve transparency effect. Some have been described in this thread.
Below is one more method…
Getting transparency and shadows at the same time may seem difficult at first, some of the methods will required you to turn off the ‘Flatten Layers’ option in the RENDER panel, but I usually prefer to keep using the flatten layer because it has several advantages over the “un flatten” mode. The most important advantage would be speed, when using the ‘flatten layers’ mode, your image will be rendered in the same amount of time whether you have 2 layers, or 16 (the other mode will requires every layer to be rendered separately therefore increasing the render time as you add layers). Other advantages are that all layers can cast shadows and glow effects. So, here is a method that I like because it allows you to achieve the effect you want in one step and it allows your artistic creativity to simulate the transparency effect and achieve the exact look that you want. Even tough the transparency effect can be achieved in one step; I will include all the steps required for this image.
We first create the base layer that will be ‘seen thru’ a transparent object in other layers. In this case I simply used the Plane3D tool with a default ZBrush texture (Txtr30) and FastShader as the materials. I have set the Plane3D.MODIFIERS.TEXURE.HRepeat and VRepeat to 8, and drawn the Plane3D to fill the canvas area.
We now need to create a new layer (LAYER
CREATE) and draw the ‘transparent’ objects in that layer. In this example I have simply selected the Sphere3D tool with a ‘Txtr01’ (A typical sky/ground reflection) and with GelShderA as the material. I have drawn several spheres within the canvas.
We activate the Shadow in the RENDER palette and do a test render.
We can see that we now have proper shadow, but we are still need to add the transparency effect.
To create the illusion of transparency we can simply use the Clone tool. While in layer 2, select the Clone tool and change its modifiers by turning on the Clone
Modifiers
Layers mode and turning off the Clone
Modifiers
RetainCenter.
By turning on the ‘Layers mode’ we allow the clone brush to copy color and/or depth information from the other visible layers into the active layers. In this case we only want to ‘copy’ some of the colors from layer 1 into the spheres in layer 2 which allow us create the illusion of transparency. To do that, we need to turn off the ‘ZADD’ draw option (we don’t want to copy depth information, only color),turn on the RGB draw option (we don’t want to copy Material information, only color) and set the RGB intensity to a low value (such as 6). Now we use the clone brush to ‘paint’ within each sphere. This action will transfer some of the colors from layer 1 into layer 2. The more we copy, the more the spheres will become ‘transparent’…
Now we have Simple reflection, transparency and shadows. We can stop here and call it a day, or continue and make it a bit more interesting…
Let’s continue…
What is refraction
Transparent objects have a property that referred to as ‘refraction’. When light passes thru transparent object it will change direction (being refracted) and continue in a different direction. The amount that direction of the light is changed is measured and specified as a refraction index .( Refraction is the reason that a spoon in a glass of water may look ‘broken’ )
Now Back to ZBrush and a quick method of simulating refraction…
In order to simulate refraction we need to displace and distort the image that you ‘see’ thru the spheres. When distorting the image, you are trying to ‘push’ colors in the direction that the surface of the sphere is facing; this can be done by using the ‘BumpBrush’, which does exactly what we need. When we use the bump brush, we may elect to only distort the colors within the spheres without changing the shape of the spheres (this is done by turning off the ZADD/ZSUB options) or we may choose to modify colors and shape at the same time. In this example I wanted to modify both (colors and shape), so I have activated ZADD and MRGB option, increased the RGB and Z intensity to 100, reduce BumpBrush
Modifiers
ColorBlend to zero,increased BumpBrush
Modifiers
SampleSize to 8 (in order to get smoother surface) and reduced DRAW
DEPTH to about 10%(we want to slightly modify the shape of the spheres, not create mountains
). Now by drawing over the sphere I was able to distort the shape of the sphere in order to get the following…
Applying some smoothing (by using the Blur Brush with ZADD on and MRGB off), material tweaking, adding local light and there we have it…
A variation of the same process…
I hope that you’ll find this helpful
If you try this tutorial, please post your image and findings.
-Pixolator
& have a good one…
Mark.
