Tutorial - Custom palette trick for polypainting in Zbrush 3
Hi Guys,
This video shows you how to make a custom palette for when you are polypainting
Enjoy!
//youtu.be/a8wO6SDdDZ0
http://www.youtube.com/watch?v=a8wO6SDdDZ0
Cheers,
Paul
Thanks Paul, that’s a great! A couple of tips to add:
  • You can clear your model from the canvas without losing your color palette by :
    1. Pressing the Edit button to leave Edit mode
    2. Pressing Ctrl+Z or Edit:Undo
You’ll then be able to add more colors before redrawing your model and continuing with your work.
  • If you save the Document you will be able to load up your palette for another ZBrush session. Just follow the first tip so that your model isn’t saved too.
Thanks Marcus!
If I make an updated version of the video, I’ll credit you with the changes.
Cheers,
Paul
