Turntable center of rotation
Hello… How can I select or control the center of rotation for turntable movies, especially for models comprising many subtools? Say I’d like one with the center of revolution on a horse’s center of mass, but the next centered on its head?
I had hoped my first question to the forum would be something interestiong an challenging… but I am a noob and this stumps me, both within the program and searching the docs.
Probably the simplest way is to use Transpose Master. Instead of posing your model just set up the center of rotation you want (for example, by using the Tool>Deformation>Offset slider) then transfer that to the original model with subtools.
Alternatively, you can use the Tool>Deformation>Offset slider and after every adjustment press Tool>Deformation>Repeat To Other.
