Hi. We upadated in Gameloft BP to Zbrush 2021.7. In our workflow we save out from BPR passes the shaded and the mask passes.
Before we don’t have the export image window pupup.
How can we turn off this popup? It is extremly anoying.
Hello @Balazs_Cserta ,
Several of the render passes default to the jpeg file type. If the file type is set to jpeg, it will bring up the cropping menu. To avoid this, simply export the image as a different file type like PSD.
Good luck!
That was that… Thank you. I just didn’t catch it is changed from PSD default to jpeg in this build of Zbrush.
Hi there! We also do hundreds of BPR exports per session at my company and while changing to PSD works around, it would be helpful if we could change the default JPG export to PSD export again.
Is there an option for that yet? Thanks!
