Trouble with SSS Renderpass
Hello, I apologize if this is a simple fix, but I have been having trouble finding a solution for this problem and I’m not quite sure where to look any further. I have been using the BPR Renderpass to export my sculpted images, but when I enable the SSS option in the BPR render setup, it will not produce an SSS Map. The BPR render will allow me to export every map except the SSS. I am using Zbrush 4R6. Are there extra steps in producing the map that I may not be aware of in order to export it?
