I have created an asset in Maya and imported it into zBrush. Subdivided and sculpted successfully. I am trying to paint a texture on the subtool using spotlight. I successfully load the texture and i can see the texture on the brush in spotlight but when I go to paint, the subtool rotates as it normally would and I can’t actually paint on it. I have created a clean file and just loaded in a cube and then subdivided and spotlight works as it should…so what could be the problem with my model/subtool that is not allowing me to paint on it using spotlight? I’m a bit baffled.
Thnaks
Ron
Turn Edit off, put Z Intensity to 100, turn Edit back on.
That did it…thank you, so much.
no problem!
