Trimming my obj causes repeated crashing
Hello friends,
I wonder if you could look at this quick video? I am importing an obj and trying to use the trim curve brush to cut away certain parts of it. I’ve tried it over and over again and causes it to crash. Wondering if anyone can suggest what might be causing this - and how I can accomplish it?
Thank you.
https://www.screencast.com/t/X7D8sjPaG
couple of suggestions
  1. change your stroke type and see if that works
  2. try and see if the Slice brush will work. - use the groups option and then just make different groups so you can delete hidden, split groups, etc.
Thank you for the suggestion. I appreciate it.
