Hi all - I am firly new to Zbrush and have, what is probably a very nooby question:
I have a dynameshed cube and I used the trim curve to cut half of it away and get an expected result - nothing strange. However, when I use the same tool on the same cube, I go to only cut a corner off and nothing dissapears or gets cut away, only a new polygroup appears and the loading process that occurs when I tell it to trim the corner says “slicing” not “trimming”… why would this be? Am I doing something wrong?
Thanks in advance all,
Ross
