Trim Curve and symmetry does it work?
Just curious if this is something going on with my system or just the way trim curve works. I can’t get normal symmetry to work as in it just does one side.
I have found a work around though using zremesher and cutting both sides, then zremesher making it symmetrical but ideally I would like to not have to do this. There is nothing in the documentation that says one way or the other concerning this issue.
Also I have the upgrade and zbrush(windows version) is crashing left and right my system is completely stable otherwise and fairly high end.
the trim brushes are not symmetrical for some reason.
But, the trim brushes only work with a mesh with no subD levels. To get around the lack of symmetry just use a mirror and weld function after you are done trimming.
could you elaborate on how to do that?
