Triiangle Shape - Pennant
Okay - total rookie question.
Is it possible to create a pennant shape - an elongated triangle in Zbrush without the poles. Here’s what I tried already. Create a cylinder and reduce the sides to 3. This creates the right angle triangle. Then I used the stretch deformation to create the pennant shape. But … since it’s a cylinder it has the poles and this causes weirdness with the UVs. I tried zremeshing and it just jacked up the edges - same with dynamesh.
I didn’t have any luck with the cube as it doesn’t allow for side allotment.
Better way to create this shape and have uniform UVs?
Thanks!
Yeah, me neither. I ended up creating the object in Max and importing into Zbrush. :cool:
Thanks!
