[attach=208306]transposemaster.jpg[/attach]
Note: all plugins are now included with the ZBrush 4R7 installer. If you did not install a plugin then run the installer again.
For the latest information see the online docs here : http://docs.pixologic.com/user-guide/zbrush-plugins/
Transpose Master allows you to pose a model with multiple SubTools by creating one combined model of the lowest resolution level of each SubTool. Once this low rez version is posed you can transfer the pose back to your original high rez model at the click of a button.
This plugin is available with ZBrush 4R6.
Installation
The plugin is automatically installed with the standard installation of ZBrush.
Frequently Ask Questions
Q: I don’t see TransPose Master in the ZPlugin palette.
A: If you did a custom install of ZBrush then run the installer again and make sure you install the Transpose Master plugin.
© 2010 Pixologic, Inc. All rights reserved, Pixologic and the Pixologic logo, ZBrush, and the ZBrush logo are registered trademarks of Pixologic. Various patents pending. All other trademarks are the property of their respective owners.
