Hi people, its posible to bee disabled from anader plugins?
message: unable to open/Create a file…
help me if you can.
tanx
help me if you can.
tanx
It sounds like you haven’t installed the plugin correctly. Can you post a screen shot of the error message? Then I will be able to confirm.
Thanks,
… reinstall the plugin and now its ok!
thank you Marcus!!!
I have this problem as well. I extracted the .rar file into my zplugs folder and everything and I restarted zbrush3. When I hit the Tpose button it gives me this:[attach=103578]errormsg.JPG[/attach]
Any help would be appreciated.
Well I figured out that apparently you have to save your ztool in your ztools folder before attempting to use transpose master with it. However I do have a model that I tried to use this on and I got some sort of Popup thing where it says “Interface item could not be found”, then something about [Ipress… Strmerge and Var,currentsubtool]]]
I have no idea what it means.
Well, neither have I without seeing the specific situation in which you got the message. Transpose Master can get confused if you have subtools with the same name. Also, avoid using a backslash () in the names.
I just ran into this exact same problem, due to a backslash in the subtool name.
Strange part is- it was subtool master that created the backslash in the subtool’s name! so if anybody runs across this thread like I did, and you use subtool master and transpose master together, keep that in mind.
