Switching to a other brush like Move while using the transpose line does not switch to the brush and turns on rbg.
The transpose line brush icon does not change. I have to select the brush twice with a hotkey to switch, cannot change brush by clicking the brush icon.
EDIT: The issue goes away after I did a clean install, the problem starts after setting the move brush to the 1 Hotkey.
When the hotkey is press it goes from Transpose move, scale, rotate to Draw with the transpose icon still visible.
why does this happen is there a way to fix this?
