transpose & action line??
Just migrated to zb3, started doing nthe first tutorial and imediately hit a wall- where do I get the action line? when I click & drag as the tutorial says I just draw on the model with zadd. The tutorial is here btw:
http://www.zbrush.info/wiki/index.php/Transpose
Did you Activate it before with hitting the “w” key? Before dragging the Action Line.
Thanks! the ‘w’ key does the trick- they should’ve mentioned it in the tutorial.
Be sure you are working with a polymesh object - transpose doesn’t work with the primitives. Convert first by pressing the Make Polymesh3d button.
Sven
It sounds like you are in draw mode, make sure you have move, scale or rotate selected and then draw your action line.:cool:
Yes…i think JohnnyBoy, is right…and since your new…here’s a picture !
jantim
God i miss this forum…
I hit the same wall, and came to ZBC, and it is awnsered in seconds!!
the tutorial never mentions the w key…
:sunglasses: :+1:
thanks guys :slight_smile:
hehe , the action line was the first thing i got , since i tried to use edit move like in ZB2 to move part of my model and it drew an action line :wink:
