Hello there, i want add a texture with only black color, with zbrush texture transparent option all black colors will be blanked, but i only need those blacks … i tried to import a psd file with transparency but the edges aren’t good at all in this case and they are seems colorful !
any tricks? thank you!
Hello @evopsy
The ZBrush texture menu interprets 100% black as transparency for a variety of functions. The simplest way around this is to not make the blacks you want to be visible 100% black–even 99% would be fine. Otherwise, switch off the Transparent texture button for that texture.
