Is possible to translate the z-scripts in Italian or not?? is Legal that
? i have translated a z-script of a centaur but i will ask you first to post it…
Tanks so much… see you soon,
Quentin
If you mean translate the text in a Note or Caption etc. within a zscript or tutorial into Italian, that’s perfectly possible (although probably some accents won’t appear). But if you are planning on translating someone else’s zscript/tutorial you should ask their permission first.
If you mean translate the zscript commands (and I doubt if you do) then that won’t work because the zscript won’t run.
HTH,
Tanks so much, i understand all, i will just translate the internal notes of the z-script…
i have now to search the original author…
If you make z-scripts send me a message… tanks to all… bye
Quentin:D
