Is there a way to repeat the last transformation ?
Hello @zzeebee ,
If you don’t rotate the camera angle, then “Replay Last” should repeat it. In other situations, the Tool> Deformation> Repeat to Active command may be useful.
Hi Spyndel,
I meant the transform gizmo. Any way to repeat the last transformation made with the transpose line or transform gizmo ?
Replay Last works with both the Gizmo manipulator and Transpose Action Lines.
When I hit replay last my camera view changes , but nothing else. Are you referring to another “replay last” than the one on the stroke menu ?
