I am having Difficulty with the timing sinking when ever I move my Skeleton for my character via Tpose Master. I know this is a faster way to rigg your character but every time I move an arm or a leg it takes roughly about 3-4mins to load then move inch by inch or less. how do you speed this up? I also have active 12+ sub-tools that make up my model.
My system is Alienware with;
Processor Intel(R) Core™ i7-10700KF CPU @ 3.80GHz, 3792 Mhz, 8 Core(s), 16 Logical Processor(s), Installed Physical Memory (RAM) 32.0 GB, Total Physical Memory 31.8 GB, Available Physical Memory 17.0 GB, Total Virtual Memory 42.8 GB, Available Virtual Memory 15.0 GB.
Any help or advice would be most appreciated. Also before I forget my model started at over 836 million polygons before I used the Zplugin Tpose-Master tool. This may have something to do with it… but then that would mean I would have to reduce the polygon count of all subtools. if that is the case any advice on how to reduce polygon count on all subtools as a whole instead of individual?
