Is there a tex program I can import into Z Brush, So I can do 3D writing. THANK YOU Curtis Hawkins/ Rembrant.
Hi Curtis
Give Elefont a spin
Elefont -Elefont is a free tool to create 3D text objects from TTF fonts
Digits when I down load file where do I put it into Z Brush. Explain THANKS Curtis.
First off, Elefont is a separate program from Zbrush. Install it in its own directory.
Use Elefont to make a DFX object of whatever text that you want. Save this file on your harddrive, maybe you will want to create a directory especially for these things.
Open up Zbrush and select the Polymesh Tool. In the Tool:Inventory palette make sure DFX is selected and press Import. You will get a file dialog window. Navigate to where you saved your dfx file from Elefont and select Open. You should now have the Text you created in Elefont in Zbrush that you can now color, texture, change materials, make bigger, smaller etc…
Hope this helps!
