Threetails Sketchbook
Hello everyone, here are the images of my work leading up to
the ZBrush 2018 Sculpt off. From the initial concept which was
over time by 30 minutes to the last which was just under the
allotted time. Ah the decent into madness. Hope you like the work.
The card was Temperance: 3Hrs or less, the challenge… Cheers
Hey guys here is a look at one of my latest pieces.
“Kairos Escape From The Underworld”
This design in intended for large scale bronze and has been designed in two orientations.
Sculpted in ZBrush and rendered in Keyshot.
The video was also rendered in Keyshot.
hope you like it.
[youtubepl]PLtFOqZ1CtCgvt8hYGKxd_yRO9f4QFcuc3[/youtubepl]
flawless design
I congratulate you TopRow
Hey guys, thanks very much for the kind words, am to pixologic for the top row honours. I’ve been sculpting away for a while, and I hope to have some more to show in the coming weeks. Thanks again.
Beautiful shapes and impressive presentation! this will be a show stopper!
Thanks Sammeh, much appreciated.
A fabulous sculpt with wonderful flow and dynamism.
The Art Deco treatment is perfect for the work.:+1:
…infinite! :sunglasses:
Thanks Boozy and Frenchy, much appreciated.
A masterpiece! Truly amazing!!
Camaleao, thanks so much.
I’ll try and post some clay renders when I can.
Yes,some clay renders would be much appreciated!!
Here is an early clay renders to check out, it turns out i only have the one.
A Nearly New One
WOW!!! This is gorgeous, thank you for sharing.
Thanks Paul.
