In all discussions concerning zScripting, there’s a consistent emphasis on zScript execution stopping after zPlugin code. Presently, I’m attempting to incorporate zPlugin’s UV Master unwrap functionality within my zScript, and I’m encountering the issue mentioned, where my code ceases execution after the unwrapping process. I’m curious to find out if there have been any developments regarding this matter.
You can run only a single Script at once.
When you are calling another plugin from your script, that other plugin runs but your script loose the hand on the process. This is a normal behavior and their is no fix or workaround.
Hope it helps,
Nicolas
Thank you @facelessmindz for quick response)
In the forum above, the moderator @MARCUS_CIVIS replied to a user’s query, mentioning that he is currently in the process of developing a special version of the UV mapping plugin. I was wondering if you happen to know whether the code is now completed or if you have access to it?
