I may not be one of the geniuses of ZBrush (I hope I can get to their level one day!
), but I do want to share with you some of the stuff I know. Lately, I have been playing around a lot with lights. I know many people have done this before me, explaining different light settings, etc. Well, I thought my little tidbits might be able to help someone out, and if they can help just one person, that’s good for me.
Okay, with the intro complete (lol) we can get down to it. In most of my works, I have vibrant colors and highlights to make the image stand out. Below is an example with the default lights and then with my favorite lighting set up I call Bright Outline.
As you can see, there is a major difference. The second shows more color and also highlights the outline of the figure, giving it a bright cheery look. Okay, let’s beak this down.
The Lights
All the lights I use are suns. There are four in total. The main one is set to the full intensity of 2. One other sunlight is set to .3 intensity and the other is set to .93. One is white, the other is blue in this case and are both set opposite the main light. Finally, there is a radial sun. This one is positioned to illuminate the edges and is set to 2. That’s pretty much how I use my lights. Moving the main light can change where the most light is coming from and changing the others can add color highlights wherever you wish. Good luck with light experimentation! ![]()
Thanks for sharing
