The Pivot Circle of ArrayMesh doesn't move!
Hello, I just want to know ‘How can I move the yellow circle of Array Mesh Transpose Pivot?’
I saw some tutorial of Arraymesh and also read the zbrush document page.
They said, Just click the yellow circle and drag to anywhere…
But the Circle didn’t move!!!
Please, help me…
Hi @boblove
It is indeed as simple as clicking on the pivot circle and moving where you want to place it. The following things must be true:
  1. You must have “Transpose” mode activated in the ArrayMesh palette.
  2. You must be using the Transpose Action Lines. You must deactivate the Gizmo 3d button to do this.
If the rings (large orange circles) of the transpose action line are overlapping with the pivot circle (small yellow circle), they may be preventing you from targeting the pivot circle. Drag the action line away from the pivot by clicking and dragging on the exterior of any of the large orange rings of the action line. This should let you target and drag the pivot.
If this does not solve your problem, we’ll need to see more extensive documentation of the problem.
Thank you!
Thank you for your answar to the question.
But I still can’t move the Pivot Point although I’ve done all of the following lists.
https://youtu.be/hQKsDSvk39M
I activated “Transpose” mode of ArrayMesh.
And also using Action line of Transpose mode.
Please tell me your opinion.
