Hi pals!
Long time no posting due to, you know, adulthood. This time I bring you an OC from one of my last illustrations called ‘The Dark Priestess’. I wanna do bundles of illustrations and 3D pieces.
So, as I had the 2D color version done, I tried Spotlight to transfer it to the mesh and results were quite good
I use Toolbag 4 to render, so I remeshed to reduce polys but had some problems with the jewels to make UV maps. I solved it spliting them in parts and then, after creating UVs, merging again conserving UVs (just in case someone need this tip
After that, I exported it to Marmoset, baked, edited textures and rendered. I’m in love with Toolbag4
Here you have the turn around vid. I hope you like it!
