Now I’m blushing!
Thank you, all, for the kind comments. I’m having a lot of fun with the site, and am glad that people are enjoying it. Glen, your prior advice was most helpful.
In the works:
:b2: I need to fix the preloader issue that is giving some IE users fits (odd that Netscrape of all things should be fine).
:b2: Build the Resources section with contents of my own creation (like butterfly wings and my wing material!) as well as useful stuff that is volunteered by such kind souls as Stonecutter and Southern. This section will never be done, by the way – I intend for it to be a regularly evolving part of the site.
:b2: The addition of preloaders for the mini-movies that house the Galleries and Resources sections. Even though the load time on them is short, it can still leave someone to believe that the site is malfunctioning without some kind of cue to let the visitor know that it’s working. Incidentally, the “trick” that makes this site load as quickly as it does despite its large amount of content is that I have designed it to only load what is necessary at any given time. If someone never goes to the Poser gallery, for example, then it is never loaded. This was done be creating separate movies for each section and loading them into the existing movie when needed – a technique that is well worth learning.
:b2: (My favorite) The creation of additional skins for the site. It has always been my vision for the site to select a different “look” at random each time someone comes to it. Other commitments have kept me from getting to their creation yet, but should be a lot of fun. The layout will remain exactly the same, so as not to confuse returning visitors, but the actual appearance of the site will change. And of course, all of the skins are going to be created with ZBrush!
:b2: As you may have noticed, the Web Ring button doesn’t do anything. Yet.
Thank you, again. And keep watching for the updates.
