Hey Ed I got a few tips for ya i left out if you wish to correct your problem as with 384 megs of (RAM) you shouldn"t be having that problem.
1)Right click on My Computer on your desktop> click Properties, and then click the Preformance tab.
Click the Virtual Memory button. Select the 2nd radio button> which lets you manage your own virtual memory.
Change the MINIMUM number to 400. Leave the MAXIMUM number alone. Click DONE. You will get a scary alert saying 'this may adversely affect your computer BUT don’t worry about it.
Reboot so the settings will take effect.
What this does, Ed is prevents Windows from drawmaticly resizing your virtual memory(swap file) on its own…which is VERY ineficient.
2)You now need to edit a system file Ed. This will make your PC use as much REAL RAM as possible before dipping into virtual memory(swap file again, lol). In Notepad, open up the file C:\Windows\System.ini for editing. Scroll down until you find a line with this text:
[386Enh]
When you see that line, look in the imediate following lines for this Ed:
ConservativeSwapfileUsage=1
If you see that line Ed, then you are fine and no editing is neded. If you see that line, but it has a value of 0 instead of 1, then change the 0 to a 1. If you DO NOT see that line at all, then add it. Add it on a line by itself Ed. Save your changes. Reboot so new settings will take effect.
3)You may have MANY other apps running in the background that you are not awaire of Ed. These can rob you of system resources, and as many peopol may believe ((system resources are NOT directly related to RAM.)) My girlfriend has 256 megs of RAM, and yet when her computer booted up, her system resources were sitting on 62%. lol She wasn’t aware that she had 17 apps running when her PC booted up.
Before doing this Ed, we need to run a test. Reboot your computer. Right click on My Computer> then click Properties, and then click on the Performance tab. Take note of what the System Resources displays. Close the panel.
Click Start, then Run, and type in (msconfig) and click OK. This opens up the System Configuration Utility. Click on the Start Up tab, Ed. What you will see is a list of programs with a checkbox to the left of each listing. Each box that is checked Ed, is what starts up when you boot your machine. Take note that all anti-virus software uses takes up VERY MUCH resources. You may wish to uncheck these to free up resourcs. I can tell you this ED…if you are running Windows ME then this is all that you must have checked:
ScanRegistry
SystemTray
LoadPowerProfile
Also if you wanna play it safe> you can always just write down everything that is originally checked before making your changes. After you make your change, click “OK” and you will be prompted to reboot.
Reboot> and then go look at your System Resources Ed. You will be surprised.
have a good one buddy and GOOD LUCK.
and make a copy of C:\Windows\System.ini and stick it on your desk top to be on the safe side.
