For those of you fasinated by Pixolators AlphaCenturytutorial I have updated my old script.
Example:
- Set Depth
- Set Taper and BS and BE if you want
- Create the Brush stroke on the canvas (change alphas to get different effects)
- Press “STORE” to save the stroke
- Press “Contour” to create the terrain.
- Wait until the script completes or hit ESC key
- If you want create more terrain strokes.
- when you are done select Autocrop on or off
- Press Make
- Adjust the 3D terrain with the + and - Buttons
I also might suggest that you use a document size of 512X512 to make your terrains to get the max resolution out of your 3D model.
