I have a samsung ativ 700t, and trying to use zbrush on it. I bought a 2 button wacom pen for it, but the upper button doesn’t register strokes while pressed, so it can only be used for single keypresses, not as a modifier. Therefore I can’t map alt and shift to the pen, only one of them (the lower button works fine). This means I’m unable to use zbrush at the moment as alt is needed for paning and shift for smooth. Is there a way to select the smooth brush without using a modifier key? (I know I’d still not have ctrl, but it’s a 4GB machine anyway, so I can get by without masking at that level, but not without smoothing.)
Thank you
