Wacom makes the best tablet and tablet drivers hands down. Most professionals use Intuos. Cintiq’s are king, but they’re pricey. I use an Intuos 4 when I don’t feel like reaching for the Cintiq. The Bamboo is a very capable tablet if you want something more entry level or cost effective. All current Wacom tablets work in XP.
Keep in mind the following when buying your tablet, though…
When it comes to tablets, bigger definitely does NOT mean better. A lot of people make this assumption when buying their first tablet. Also, I find the monitor to tablet size ratio doesn’t matter much. When trying to balance it all out, it all comes down to your work area and what the tablet is being used for. For example, using a 12x18 ideal for drafting or pattern making but is not so good for digital sculpting. It’s quite cumbersome and not very efficient. For general artistic usage and digital sculpting, I’d recommend a 6x9 Intuos 4 (medium) if you have the cash. This size is good, real estate wise, and allows you to make strokes comfortably with more control. I’ve even used a 4x6 tablet with a 30" monitor no problem. But I find 6x9 to be optimal. I think this is the most commonly used size for CG artists.
Once you get used to your new tablet, try exploring all the features that are available in the tablet driver control panel. Learn how to customize the tablet and pen settings to fit your handling and painting style for better control of your strokes. Drawing applications like Painter offer additional tools to tweak brush tracking and pressure sensitivity. Additionally, there’s lots of great feature to enhance your workflow system wide or on a per application basis in the tablet control panel.
Last, try to formulate an understanding of how tablet technology is being used and what will be available to you in your final choice. Each line of Wacom tablets offers something different in technology. Some applications have better support tablet technology than others. It’s good to understand what your tablet will be capable of in each application. It varies from app to app and it can make a difference in the work you produce. For example, Bamboo touch pens have 1,024 levels of pressure while Intuos tablets have 2,048. This leaves the Intuos tablets being more responsive to pen pressure and more accurate. Intuos tables also have support for tracking 360° barrel rotation when using the Art Pen (sold separately) in applications like Painter and Photoshop, which Bamboo tablets have no support for at all. Unfortunately ZBrush, like most apps, don’t support 360° barrel rotation… Which would be cool as hell if you could turn this on and off in ZBrush to rotate brushes with alphas. But that’s another thread.
Anyway, Good luck with your choice. Buy anything from Wacom and I’m sure you’ll be very happy.
raru
