I am having some trouble with my Wacom tablet. It is a Graphire4 (CTE-440) that normaly works fine but the pressure sensitivity is not working. Any suggestions?
Is it only not working in ZBrush, or is it also not working in Photoshop and other applications? If it isn’t working in any software, then you should contact Wacom.
db
You most likely need to install the most current drivers from the Wacom website. That will probably resolve your issue.
i got the same tablet and found it does that now and then reinstall the driver or update it
