Svg in coral draw to zbrush
Hi, I been trying to import svg to zbrush from corel draw with no luck all vectors closed, but if i download svg from the net it works fine…
Any ideas why corel draw svg’s dont work?
thank you
Hi @tom356 ,
Please make sure your program version is fully up to date. There have been a number of issues related to SVG import that have been addressed in recent patches.
The typical reasons would all apply. The curve may not actually be closed, there could be overlapping elements, the program could be exporting some kind of data that isn’t supported like Layers or clipping paths. There could also be some sort of compatibility issue not explained by the above.
Try creating a simple, solid closed shape like a square and exporting it, then importing it into ZBrush. If that works then the issue might be with something you are doing in the program.
If that does not work, please contact ZBrush support and provide the files for examination.
Thank you!
