Hi all,
I just imported a bunch of svg’s into zbrush (created in adobe illustrator) and everything came in fine except for a complex floral pattern. As you see in the photo, the ‘closed’ islands are disregarded and filled.
I tried increasing the anchor points in illustrator, exploding the compount path (hoping that it would look bad in illustrator but import nicely in zbrush) but nothing.
I’ve imported similar topology again (a shape with holes) and it has worked fine.
Is it the complexity of the shape or could it be something else?
here is the svg file in case someone wants to have a go at it: fl1.zip (20.0 KB)
