Surface Noise not trasnferring to Keyshot when I BPR
My surface noise isn’t rendering in Keyshot when I send it over via the Bridge. I have ZB 2021.6.6 and Keyshot for Zbrush Pro 10.2.
Thanks for any help.
Hi @Germinate
A quick test here doesn’t turn up a problem sending to Keyshot with surface noise. We would probably need to take a closer look at the content you are working with to see if we could spot an issue specific to that situation.
Please head over to Pixologic Support and start a conversation there so we can investigate your problem in more detail.
Thank you!
Thank you @Spyndel. I will do that :+1:
