I get an error when I go to this web page https://support.pixologic.com/
It worked fine yesterday.
Here’s the error message:
ERROR: Domain does not match license key file domain (), please change the product path to match the domain under Admin CP > Settings > General Settings
This Product will not work properly unless untill that value is changed.
[WARNING]: Database Version Tag () and File (3.60.03) Mismatch!
Please update your files to the latest revision, This error happens when your database structure is different than the PHP files you are using.
Warning: Cannot modify header information - headers already sent by (output started at /home/supadmin/public_html/swift.php:355) in /home/supadmin/public_html/includes/functions.php on line 1628
var themepath = “themes/client_default/”; var swiftpath = “”; var BLANK_IMAGE=“themes/client_default/space.gif”; var swiftsessionid = “”; <img src=“http://www.zbrushcentral.com/pixo/atn.gif”>
