I’ve been working on this skin type material on and off for a couple months now and realized that when ZB comes out, there will probably be even better materials on their way. I’ve been wanting to upload it for a while, but I keep trying to refine it more. I’m still tweaking it here and there, but this is what I have so far.
The first image is with a texture map, the second is without. The texture will appear better if you reduce the colorize diffuse a bit in the 4th channel of the material.
Here’s the material and light setup I used.
I hope some of you get some use out of it before the ZB3 wave hits!
