Subtract boolean operations with sub-tool question
Is there any way to use boolean subtract functions within the sub tool menu? I know we can use the remesh function but results are messy which can be resolved with the projection function but I’m not able to do the same for subtractions. The boolean subtract using the insert mesh tool works well however is kind of cumbersome because when you place subtracting mesh it follows the surface being applied adding extra work to align to piece which doesn’t happen when using sub tool menus.
Thanks for your support
I believe this is what you’re looking for.
http://docs.pixologic.com/reference-guide/tool/polymesh/subtool/
