Subtools all same tone?
Hi! How to make the selected subtool the same color of the others? You know, the selected subtool is by default brighter than the others, I know that there is a way to deactivate this option but I don’t know where…please help!
You can Shift+click the paintbrush icon (next to the eye icon) in the subtool list. (This turns on ‘Colorize’ in the Tool>Polypaint menu and effectively fills all the subtools with white.)
no I mean, I don’t want to colorize the subtools, I want to turn off the option that highlights the selected subtool. The object that I’m working on is lighter than the other
as you can see here the color of the brachelet is lighter than the arm, I want them to be the same color without render them
Some settings in the draw pallette.
Your only other option, other than what Marcus suggested (which will give you 100% same brightness on all sutools), is to change the ‘Inactive Subtool Dimming’ slider in ‘Preferences:Edit’ to maximum which will give you 90% brightness on inactive subtools. Note: You won’t see the change until you click and drag on the canvas to rotate.
thank you all for the answers!!
