Hi all
Using 4R7 64bit P3 on Windows 7 Pro.
I’ve been having something of a strange problem… I’m working with a file that is four subtools, each dynameshed at around 400,000 polys each.
Basically I’m working on them with clay buildup adding and subtracting as you do. All is well but occasionally when I hit Ctrl_Z the entire subtool I’m working on disappears, the active polycount goes to zero and the thumbnail in the subtool list vanishes.
Redo doesn’t bring it back. The undo history bar remains but you can click anywhere in it and you still have a zero polygon subtool. It’s quit and reload time with everything since the last save or autosave lost.
This is happening fairly often. If I do an two hour session at this it will usually happen once or twice.
Does anyone know anything about this?
