Subdivision Levels
I just started learning this software and I just find a big closed door.
I’ve set some Zphere and create an adaptive skin for a bust, need to create some edge loop on eyes and mouth areas, but, sometimes in Geometry the Del lower subdivision levels Button is Lost, I can’f find it! Why??
Please help me in this elementary Dilemma!
Thank you!
ZSpheres are a geometry generator. They’re used to block out the model’s shape before you proceed to regular sculpting. They don’t have true subdivision levels until you make an Adaptive Skin. Nothing that edits the model’s geometry will work until you’ve skinned the mesh.
Thank you for the fast response, but i’ve Already generated the adaptive skin. My problem is to find the delete lowest subdivision level button in geometry menu. I don’t know, but sometimes it disappear with the divide button ecc ecc. maybe i’ve Forgot some passages?
It might be because you are making a skin that has DynaMesh applied to it. Try the steps in the image.
Thank you so much zber2!
