Stuck at Layers
Hello!
I want to morph between 2 characters.
I have one base mesh, and I have a version of that base mesh with altered topology but with some point count, etc.
Basically, I only moved points around.
I would like to blend / morph between the two.
To do that, I tried the following:
I loaded the base mesh ZTL, and switched to Edit+Draw mode.
Then I clicked “Layers” and clicked the “+” button.
That would create a new layer, and REC was highlighted (does that mean it’s on or off???).
When I click it again, it quickly switches to black, but then immediately gets highlighted again.
Now I load the second model which has the altered topology.
ZBrush switches to the second model, giving me a new Layer menu without any layers added yet.
Where am I doing it wrong?
Thank you!
Okay, I got it.
2 points:
  1. The REC button is broken. Playing with the slider next to it makes it stop while clicking REC doesn’t.
  2. It only works if I import an OBJ, not a ZTL.
