I am having a problem with the inventory function under stroke palette of zbrush 4R4.
Usually i have no problems replaying my strokes but for this instance it quirks up and instead of replaying the stroke i previously recorded, it plays out a camera change instead which i did not record whatsoever at all. Have a look.
http://www.youtube.com/watch?v=-okdgtFp5EU&feature=youtu.be
Apart from this, i also do not know how to properly loaded an exported recorded stroke from the inventory. I tried loading the txt and zsc files from the zscript loader and nothing happens. I researched the zbrush wiki and found this,
http://docs.pixologic.com/reference-guide/stroke/inventory/
it says
" Export All Strokes. Press Export All Strokes to save recorded brush strokes to a disk file. Stroke files can only be loaded as part of a ZScript or Macro using the [StrokesLoad] command."
I am using R4 and i dont see that button anywhere in the interface, but it seems like a command i have to input in the zscript itself. I am no pro scripter so please help me out with the coding.
Thanks.
