Hi I just recently got a strange error while trying to export maps using the Multi map exporter plugin. When I try to merge maps and select a place to save the file it seems to make all the process correctly but once it finishes the subtool I receive the message “error encountered while saving a file”, I tried to save the file in the default carpet “ZExportImport” and strangley it doesn’t happen there, it makes the file correctly but if I try to make it somewhere else I receive the same error every time, please help.
Hello @fenix666,
I don’t have this issue. There may be something amiss with either your installation, the file you are working with, or your OS environment. The community usage questions forums are unlikely to be able to help you. Please contact Pixologic Support.
Thank you!
