Hi.
Is there some way to set a fixed size for insert mesh brush size as happens with alphas? I can’t find the way. I just want to insert one here and one there, of the same exact size.
Thank you.St
Hi.
Thank you.St
Start to draw the insert mesh then press Ctrl. The size it jumps to is adjusted by the Draw Size.
Oh thank you, it works great! Thanks a lot!
No problem! You’re welcome.
