Star ZSphere Problems!
Hey guys
I’m new to ZBrush, but I have a quick question about ZSpheres.
I’m trying to make a star shape using them.
So here’s what I’ve done:
Select ZSphere tool.
Create big ZSphere in middle of screen.
Turn Symmetry on X, Radial, count 5.
Go into drawing mode.
Draw a small ZSphere at the top of the big one, which will draw a total of 5 due to the symmetry setting.
Move top ZSphere to top of screen (which will move all symmetrically).
Preview mesh.
And it is completely screwed up :slight_smile:
It’s all non-uniforly meshed, which is weird because it is perfectly symmetrical!
Such a simple first ZSphere model I chose to make, a star, and still it turns out wrong, typical! lol
Can anyone help me out here?
Thank you!!!
First, download XYZ Adjust plugin, install it and read the documentation.
XYZ Adjust by TVeyes
Another explanation of the fundamental issue with ZSpheres…
Bonecradle’s hand building exercise
Finally, take a long, leisurely look at Jason Belec’s definitive thread on sculpting with ZSpheres, take the time to do the exercises…
Jason Belec’s - “A Little Challenge”
Remember to think of the ZSphere as multi-faceted geometry, the simplest ZSphere is really a cube, and when you build on it, you are extending the faces.
Use Xres, Yres, Zres to determine the number of faces for each ZSphere node - for instance, use XYZ Adjust to edit your star’s root ZSphere: x=5, y=5, z=5.
Sven
Also, download and view one other ZSphere-hand building script:
TomLong74 - EZ ZSphere Hand
checkout the illustration showing X,Y,Z res for each of the ZSpheres!..
