Spotlight widget will not display in 4R2b
For some strange reason I can’t get the spotlight widget to load on my system when running the 4R2B release.
If I try to launch the spotlight by double clicking on an image in the light box it will load into the texture slot but the spotlight widget will not appear.
if I try it with version 4.0 it works just fine.
Has something changed?
Any idea why this might not be working for me?
Thanks!
Kind Regards,
Joe
After you load the first texture into the texture slot, you have to go to Texture menu and click ‘Add To Spotlight’ button first. After that, double clicking on a texture in Lightbox will add it to Spotlight.
That would be fine, if I could do it. However, my problem is that the “Add To Spoltlight” button does not even exist in texture menu! It’s is gone. If I go to ZB 4.0, it is there just where I would expect to find it… but in the new release, it is missing.
What you are showing is the texture palette. I was referring to the Texture menu. See image below.
Oh, sorry my apologies. I was confused because those buttons used to be available in the texture palette previously but they seem to have now been moved and/or removed.
Thanks heaps for your help… I’m happy to know that this was user error on my part and not some weird bug!
Thanks again for taking the time to help me, much appreciated!
Kind Regards,
Joe
No problem Joe. You’re welcome.
