Spotlight has Disappeared ????
Hello
I am usinf ZBrush 6, all is well, but seems I can’t open SPOTLIGHT all of a sudden ???
Ive restarted, Shut down… …when I try and open Spotlight I just gat an empty frame, the SHIFT Z ketsyroke gets no responce either !?? Can some one please help with this strange SITUATION ,AND THANK YOU !??
Randy M
I’ve never heard of that before, but I would try a fresh install if I were you to see if that fixes the problem. If that doesn’t fix it then I would submit a support ticket after doing some google searching in case someone else has had the same/similar issue.
Do you have a project open for Spotlight to work on, or tried on a different project?
